Aft Lighting
CC49
Jul 29, 2012
1
Beneteau 49 Coral Marina
All interior lighting works with the exception of aft lighting in cabin and head. Checked bulbs and they are fine. Don't know what to check next. Any suggestions?
Nov 8, 2010
11,386
Get a voltmeter. Make sure you have +12 at the fixture when the switch is on. Also check on the battery side of the switch, they can fail too. If no joy see if you can get +12 reading from the + wire to another ground. Should be a simple problem.
