aft lighting , where ?
markus
this is my first sailboat, and it needs a lot of work. I can see under the aft storage box , the one that has access to the stearing , i see 2 wires, running into a hole, next to a vent tubing, but i have no idea where its suposed to be comming out, on the very back of the boat ,it looks like some bondo has be added to an area about 3" by 4" on the back,port side( bout the size i would think a light would be) and very shody work at that, but without any referance to where a light should be ,,im stuck. Not shure if i need to dig all the bondo out and put a light their, or just repair that spot., depends on whether a light should go their. On the forward light , i have wires but no light allso , think i can find a good spot for that light , I have replaced all the breakers in controle pannel and have power to all that i know of, replaced all the inside lights, got the bildge working and have power to the bottem of the mast, just FYI. Thanks, Markus
bob Gorman
Coast Guard Requirements
You shoud probably start by familiarizing yourself with the standard GC lighting specs for different size and type vessels. Not only will it help you put your boat back together, but it will help you understand what you are seeing when you are out there with the rest of us at night. I suggest a copy of Chapman's Piloting, you can get at any marine supply store or Amazon.com
