Aft Cabin light is out, how do I get at it?
K
keel_haul
The aft cabin light is out. How do I get at it. The light in the main cabin is on a panel that one can release. The aft light seems to be glued in place with no inspection panel near it. It does not seem to unscrew or snap out. Any thoughts are welcome. I am in the dark back there. Thanks
Dec 5, 2003
89
Hunter 260 Whitney's Marine, Jacksonville, FL
Shoudl be same light as 260...
Snap the plastic lense out of the housing (like you were going to change the bulb) and the are 2 screws there that will you remove to separate the light "housing" from its mounting location if you need to. One note, you won't be able to see much by removing the light from the ceiling, there is only a small hole big enough for the two wires to go though and of course the scren holes.
K
keel_haul
Thanks Darren
It didn't look as though it would snap out. I will take another look and put some gentle pressure on it.
