aft cabin cushions
bryan case
Can anyone help me out with the diminsions of the aft cabin cushions, I purchased a boat without cushions and need to make some new ones.
Sep 20, 2006
2,955
Hunter 38 Georgian Bay, Ontario, Canada
make a template
Get some heavy kraft paper from a hobby store. Cut and tape a template of the area that you want the cushions. That way you'll be sure they fit to where you want them.
Steve O.
check with mfg.
Some aftermarket cushion makers have patterns for popular boats.
Dec 2, 1999
15,184
contact US Yacht Cushions
Bryan: Check with US Yacht Cushions in Florida. You should be able to find them in the archives. Good work at reasonable prices.
Jun 4, 2004
844
Hunter 28.5 Tolchester, MD
Hunter 28.5 web site
Check to see if there is a sistership nearby you might be able to visit and measure the cushions. Due to the taper against the hull, the outside or portside edge is tapered; smaller at the bottom face than at the top side. Try : www.huntertwentyeightfive.com
bryan case
Making a pattern
Found some good info on making patterns, check out http://www.newjsi.com/HTML/pattern_instructions.htm
