We just launched our 74' O'Day 22 on Saturday. We hadn't noticed until now that at the aft end of the boom, the bolt that holds the flat piece of metal (that the main sheet block attaches to) on the end of the boom is really loose. I'd guess there is a nut, inside the boom, but the nut has worked loose, and we can't tighten or loosen it.
We're worried that our main sheet is going to pop off mid-sail...
I drilled a 1/8" hole into the side of boom; thought I could get in there and hold the nut still and tighten the bolt, but no luck. Looks like the next step is to try to drill out the rivets and remove the aluminum piece at the end of the boom? but I don't want to do more damage than good.
Anyone familiar with this, have any tips? I'm pretty sure it's the original rigging.
Thanks,
Peter
Thanks,
Peter
