Trailering...
Well, if anyone has run into every problem you might see, it's been me. As Warren stated, getting it on the trailer straight can be a problem, but you would have that problem with a swing keel or power boat as well. Getting it deep enough into the water is definately a problem. Most launches I've found in my area just aren't made for this! As Warren also stated, you might want an extension for your hitch. Another idea is to get a four inch drop hitch, and put it in up side down as to raise the tongue of your trailer three inches. This lowers the tail of the trailer which allows the back end off the boat to float sooner.The trailer I have isn't stock and the boat sits a bit high on it. One of the MAJOR things to watch out for at any dock, make sure that there is no drop off! I lost my trailer over the lip of a six foot drop off at the end of the boat launch. The water level in Lake Mich. was down five feet least year. I wish that they would have posted a notice that was more then a 3" x 5" card so I would have seen it. Now I have an extendible pole that I walk down the pier with poking into the water to see if theres anything I should be aware of before launching. Trailer recovery isn't fun. Of course, when the trailer fell out from under the boat, the boat launched beautifully!I've had many other problems with boats and launches here in Milwaukee, and have found only one worth using. The two biggest problems though have been the drop off at the end of the launch and finding one that goes in at steep enough angle to prevent me from having to back my van six feet into the water before the boat floats. I don't think that a center board model will be any diffrent though. Gaining that few inches isn't going to give you much if the launch is just too shallow for sailboats.BTW, where in the Great Lakes are you?Josh
