@Page { margin: 0.79in } p { margin-bottom: 0.1in; line-height: 120% }
Looking for some advice here. I know that the subject of Bimini tops for Hunter 23’s has been worked over a number of times in this forum but I can’t seem to find the advice that I need.
It appears that most of the commercially available tops have a minimum length of 60”. The distance from my main sheet to my backstays is only about 53 inches. I really do not relish the idea of moving the main sheet attachments 7” forward on the boom and I am not sure that I am up to cutting holes for the bacKstays to come down through.
I have a frame that I can recut to fit the boat but then I am into sewing a fabric top for the frame...I wonder if all of this is necessary??? Does anyone have a recommendation for a place to purchase a top that has a length more like what is needed on a H23? My measeurements suggest that the width ought to be around 83-85 inches, height from side deck about 43 inches and length about 53”. Anything larger than this is going to require some major modifications….HELP!!!
