Paul Higgins
I have a Adler Barbour Model DCM-12. It was working great then on a long cruise the fuse blew. I replaced the fuse but it still does not work, even the fan does not turn. I jumpered straight to the fan wires and it did work. I don't see any overload switches so I think the Danfoss control module with all the electronics on it may be shot. Can you think of any other tests I can do to be sure? Also, I think it may be too hot where it is which is in the port locker and it is open to the engine compartment. I know there are fans you can get to cool the unit. If I get one, should I be cooling the compressor or just provide cool air to the evaporator? Thanks
