Hi all, well she is now launched and sat quite happily in the local canal! It all went well and no leaks which is a blessing! Just a question about the throttle.....
I had to motor 50 yards up the canal and discovered that I seem to need a lot of throttle to get the boat to move forward.... it may be me, as I have nothing to compare it with, but I was wondering if this is normal?
The prop does not go to "fully coarse" until the throttle is pretty much wide open.... is there a special way to set up the relationship between pitch and throttle setting? I do remember being very careful about putting it all back together and followed the instructions very carefully.... so I am sure it is right as far as the reassembly is concerned but I am unsure if I should be able to do some "fine tuning".
Just off to sort out all the bits of string and connect the electrical things from the mast now - luckily it is only a 15 min drive away!
John
ps lost all my photos from Flickr... I had some finger trouble! I have uploaded a few of the launch...
John
