My current Wide Open Throttle on my Hunter 40.5 is 3200 rpm (Clean hull, clean prop). Spec for the Yanmar is 3600 so I am a little over-proped right now.
I have checked the tach with a handheld photo tach and it is very accurate so I know its not a Tach vs actual problem.
On the next haul I am considering adjusting the MaxProp pitch, which has fixed points for adjustment. I am concerned that then next notch in adjustment may make me under-proped. Is it better to be over-proped (the amount I am 3200 vs 3600) or to be under-proped. Not sure what the next pitch adjustment would do but just wondering.
If someone has a Hunter 40.5 with a MaxProp what setting do you have it on right now and how is your WOT at that setting.
Thanks in advance
Thanks in advance
