Help! I just put my mast up with my new rigging and I ran into a problem. I need to tighten the turnbuckle and install the cotter pins on my forestay but I can't access the turnbuckle completely. I have a CDI roller furler and I can't raise the drum high enough
. If I read the manual correctly, I should be able to do this. Has anyone had the same problem?The only solutions I can think of are: 1) Using one of my sheets acting as a forestay, undo the forestay/furler and remove the drum, tighten the upper portion of the turnbuckle, pin it and then try adjusting just the bottom portion or 2) Again using the sheet as a temporary forestay, cut down the plastic luff slightly hopefully giving me enough wiggle room to adjust the forestay (but not removing enough to cause the jib not to hit the pulpit and lifelines).Here's another thought, how do you measure forestay tension with the furler on?Manny
