Me too............................
I re-thread my Dutchman each year because it is so much easier to remove the sail, fold, wash it, etc without the Dutchman. Last year I marked the control lines as they exited the pockets. I figured that this year the re-install would be a cake-walk. Wrong.My lines are too tight. Now I need to wait for a wind-less time to make the adjustments again. Now realize that when you WANT wind, it's calm and when you want CALM it blows stink.If I remember correctly, the Dutchman manual says that the lines need to be slack enough so that the pockets drop down to the top of the boom and the sail flakes on top of the boom as well. You don't want the lines so tight that the pockets "stand-up" and have the weight of the sail on top of them. I will re-read the Dutchman instructions along with Chris' guideline.However, when the system is adjusted correctly, it works pretty well. However, I always need to straighten out a few of the flakes after each drop.
