Popped spreaders
Do you know where I can get more info on the ARC incident? As far as the tall rig goes, we like it, although I don't have anything to compare it with, other than our last boat (C&C 37/40R). The B49 doesn't point as high probably due to the difference in keel draught (the C&C was a foot deeper with almost same height mast). B49 is faster off the wind due to waterline and, I suspect, hull shape. In the couple of months we have sailed her we have had no problem hitting 8 - 9 knots in 15+ knots of breeze. I think fastest has been almost 11 knots in 20 knots of wind. Our 37R would never do that! The boat is very stable, and it takes a lot of wind to overpower her. We sailed in 20+ last fall and were really just beginning to think about reefing. One drawback are the stock sails which, although bulletproof, are hardly suited for light wind sailing. I found a used kevlar racing main with more roach that we are going to try and we are going to change the headsail to something lighter and maybe bigger. I think stock genoa is about 135-140%. Better sails will definately improve performance. We are sailing on Lake Ontario which is primarily light wind sailing. One problem we had was with the boom bails, one of which blew out one night. The dealer ordered new ones which were of a different design and more robust. As per this forum I am looking at adding a Navtec hydraulic backstay adjuster. One interesting thing about the tall rig is that Beneteau do not change the forestay attachment point on the mast i.e. 'I' dimension does not change only 'P' dimension and the 'E' dimension is a little longer. I could never get a straight answer from them about this, probably a cost thing.
