Adieu from a former Hunter 170 sailor
Mike G.
Hi all, Well, I took the plunge and bought a bigger boat-- a 1987 Compac 19 keelboat. Picked it up last weekend and sold the Hunter 170 just today. Thanks Sailboatowners.com and Hunterowners.com-- the first query from the ad got the boat! I watched the buyer (who came up from Miami to see her/get her) drive away, until he was all the way out of sight. Good times we've had for 2 1/2 years on our 170. We'll miss her. I'll still stop by the 170 site every now and then to see what you guys are up to. Fair winds, and best wishes, Mike G. Alachua, FL
Rick S.
Congratulations!
Mike, Congratulations on the move to a bigger boat, and the quick sale of your 170. We'll miss you among the ranks -- your contributions to the forum were numerous, always helpful, and always positive. Have you found a marina/berth for your new boat? I'll be interested how your new boat sails and handles compared with the 170, and how your crew likes it. I'm sure others will, too. Please let us know -- and post a picture or two. Best Wishes Rick
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
We'll miss you
We'll miss you on the 170 forum Mike. The Compac has character... nice boat. I too would like to here your opinion on how the Compac handles compared to the 170. Enjoy your new toy. JerryA
Mike
Thanks, & I'll report back re: Comparison
Hi guys, Thanks for your comments. My wife and I are planning to take our maiden voyage on Freebird tomorrow (weather-permitting, as always!). Since the Compac 19 has a 2' fixed keel, we'll be putting her in at a large ramp on the St. Johns River...about 50 miles south of Jacksonville. I rigged her for my first time in the driveway yesterday and everything's bigger. Shrouds are much thicker gauge, mast is heavier and makes that familiar *ting* that the halyards on good sized keelboats make when they slap the mast, jibsail is about twice as large and with the CDI furler it's about 3 times heavier, etc. The piece de resistance on the Compac is the bobstay, a cable which extends down from the forward tip of the bowsprit and down to the bow. I used it to tension the rig- it pulls down on the forestay, tensioning the backstay at the same time. The designers of this boat built it heavy- the porthole frames and hatches are solid bronze. I can't wait to see how she handles. Breezes are supposed to be around 10mph tomorrow- so nice and easy should be the order of the day. As for slip/docking- we're probably going to keep her rigged on the trailer at the marina, and then prep her and back her right in each time we go. This as opposed to lying her in brackish water, at a slip. I don't want to have to fuss with bottom issues that much. Hosing her off after each use will be easier than the occasion haulout and resultant bottom work to be done. I'll send a first report of how she sails later this week. Happy 4th to all, Mike G.
Tereza
Jun 10, 2005
185
Hunter 146 Candlewood Lake, CT
Congrats!
So long, and thanks for all the posts!! ;) Best of luck with your new boat.
Mike
Former 170 sailor's trial run in new Compac 19
Hello Rick, Tereza, Jerry and Benny, Thank you all for your best wishes on my new boat purchase. Here's a quick rundown on our maiden voyage yesterday in "Freebird". My wife and I trailered her to the marina I used to sail the 170 from on the St Johns River in Palatka (about halfway between Orlando and Jacksonville). We rigged her as I'd done also Saturday in our driveway as a trial run. Took about an hour and 10 minutes! Backed her down the ramp, tied spring lines to the dock. Stepping aboard, the boat barely moved under my 160 lbs. Then, *Caplooey*!!, the 6hp 4 stroke Mercury wouldn't start. I kept losing bulb pressure everytime and the red light on the motor kept coming on. I popped the engine cover and, while priming the bulb again, noticed gas SPEWING from a nib above the carbeurator. So I immediately resigned to no motor for this trip. Don't worry, my wife reminded me numerous times that I'd neglected to tank-test the motor at home! A nice couple in a Boston Whaler at the fueling dock (who used to own a Prindle and love sailing too) offered to tow us out to the first daymark- just out enough to catch air and not worry about having enough searoom to avoid the slips further out into the channel. We took the power tow, hoisted the main and the tow-ers threw us our long bowline. We were off. We immediately unfurled the 130% or so jib and took off. The wind was predicted 10 out of the east, but had freshened during the engine fiasco past 15knots...and was in between 15 and 20 when we finally got out there. We started on a strbd. tack and I used the port winch to haul in the jib close. Looking at fixed points (daymarks), and past that to land, I was really impressed with the headway we were making. She's not a Melges 24, but not slow either. Although I do think we were making a slight bit of leeway as well- due to the hefty but only 2' shoal draft keel. We took some puffs above 20 knots and the boat heeled up only slightly. I didn't even think about reefing the main or the large jib. I headed up with a couple of the puffs and the sails luffed more readily that in a 170- or a faster keelboat for that matter. I think that because the jib does sheet in as closely on this boat than some others, that you lose airflow more quickly when heading up slightly. Once we settled into a long tack, my wife and the dog went below to lay down on the v-berth. She exclaimed that she could easily fall asleep on this berth, so that wasn't bad to hear. We're planning some weekend/overnighters/trailersails to the Keys with this new boat. We sailed south toward the ICW bridge (the standard big, concrete 65' center clearance deal) at Palatka, and then back north to the marina's channel daymarks. Just off the ICW channel markers, we dropped sails, dropped the Danforth, and went for a swim. Put the hotdog bun-like lifejacket on the mini dachshund and brought her into the water too. Life is good. We got back aboard, pulled anchor and the boat beared away, off the wind. And a bigger blast of wind came, but I was still able to get the boat head to wind as my wife raised the sail. In our 170, we'd have had to let her go 360 around until coming back around into the wind, and then raise sail. This keelboat points to wind extremely well, and won't bear off (with sails down) as faster daysailers do. The marina's on the west shore and the wind had been blasting out of the east all day- so we had to run in to the dock/ramp. I rigged one of the two anchors into the cockpit in case we needed an emergency brake. We dropped the jib and ran in on main alone. A ways out, we dropped the main and coasted in, turning hard to port/the dock at the last second and then leveling out straight again. Success! Our little V6 Ford Escape suv (4 wheel drive) pulled our rather dense little yacht out with aplumb- nary a slip on the ramp. A big relief! Aside from all the positive conclusions I made about this boat- one is that we will dry-store her, mast up and fully rigged, on the trailer in the marina yard. The rigging learning curve is just too steep. Even when you know what you're doing- it's nowhere in the ballpark as easy as rigging a daysailer. One psychological barrier is that, the gunwale is seven feet off the ground when she's on her trailer...so any moves from the ground to the cockpit are made via large step ladder. This disconnect with the ground is just daunting. We had nowhere near our hottest day of the summer in Florida yesterday--- maybe only 92 degrees-- heat index 98??-- but it's just morale-busting rigging for over an hour in an 11 UV index! I happily just registered the vessel today at the county tax collector's- so have to add the FL numbers to the hull this weekend. And many other tweeks/personalizations need to be done (West Marine's smiling!)- and best done in the comfort of the driveway, so I don't foresee dry berthing Freebird until the end of July. I'm going to take my time- definitely going to do it right! Talked to the marina ops. manager and the dry berthing is only $30. more a month than the outdoor mini storage slot we currently use-- so I'm glad it's a good deal. There are several Precisions, Catalinas, a Montgomery 17, 3 Hunter water-ballasts and other sailboats there too. And the folks at the marina are very nice- the powerboaters even give you the time- which you can't beat! (sailors are always so hard on the powerboaters...) I will have many more reports as we weekend-camp up and down the St Johns, and eventually trailer to other FL destinations. I hope this wasn't too "windy" a reply! Happy sails, Mike G. s/v Freebird
Rusty
Glad to hear you like the new girl!
Mike, Sorry to hear you upgraded... Best wishes to you on the new Compac. My wife and I have looked over a few down at the Boathouse in Madison last fall and they do look terrific. Possibly one day... I really have my eye on an old Ericson 27 if I can find one. Would fit in Lake Michigan just perfect. Always on the lookout for one on the cheap! Ran into George this weekend at our local McDonalds. He is handling his 14 footer quite well. He spent the past week on the lake where we have our cabin, but I was not able to meet up with him. I did see him sailing on Thursday as I had to run up and let a plumber into the cabin. Ran into him by chance on his way home... Strange how that worked! Best luck with the boat. By the way, anybody know who has the 170 on Ebay. He has made some upgrades and references this website, so he has spent some time here. Any ideas??? New York state I believe. Rusty
