Hello all,
I just bought a 1984 hunter 27 with a Westerbeke 10two diesel engine. It sat in the water for the winter without being winterized and I have no idea how much fuel is in the tank (not removable and is a dark green plastic so I can't see how much fuel is in it). The system has a Racor R12S filter between the tank and engine. It is my understanding that this filter is for very small particles (2 microns????). Seems like I should mount a larger filter/water seperator between existing Racor and fuel tank???? Any suggestions? Or should I just fill the tank with fresh fuel, change the filter, add biocide, and add water treatment and run it up and down the river and change filters again? I am having all the fluids changed and the coolant system flushed mid month. I am going to buy the pump and change the oil and filter myself. Not sure if I wanna try the tranny fluid (I haven't seen much info online for this service, but assume similar to engine oil). Mainly, I want the diesel mechanic to diagnos a leak from the raw water pump and inspect the motor. I am gonna try and get as much of the easy $100 hour easy stuff done prior, but want a good mechanics blessing. I know this post is all over the place, because I already took my sleep meds, but any input to get this motor and power system in good running order would be much appreciated.
Thanks
JB
Thanks
JB
