Hello all,
So I have been looking to upgrade my house bank...... I can get 4 6 volt T125's in the original engine compartment, however want to add two more. Would also like to do this without ripping up anything. I do have a place which is about 8 feet away and figured I can put two more T125's (in series) there and parallel them as the last in line with the other 4 with the neg going to the neg bus. Right now I am using 2/0 wire.... Is it wise to use the same or should I get a bit larger with wires leading to the 2 remote batteries? Also, would it be wise to fuse this bank (main bank is already appropriately fused)? Does it create a significant issue with some of the batteries of a bank in a different place??
I know it is best to have the bank all together, but this is just not possible unless I move the entire bank about 12 feet away from Alternator (Balmar 150 amp) and main battery switch which would actually be in a cool area with ample room and ventilation and could accommodate the weight easily, however this is in a port aft lazerette not center-line as current bank is.
Any suggestions / better ideas from those of you that know more??
Thanks
Greg
Thanks
Greg
