Adding structural support after removing the diesel tank from the bilge?
Oct 31, 2019
8
So we finally removed the old leaky stinky diesel tank from the bilge.Tips for other doing the same thing: removing it without cutting it up doesn't seem to be possible, get your dremel ready and fill the bilge with water to lift it up a bit.Searching the group I found a few mentions claiming that the tank actually added rigidity to the hull. Is that true? If that's the case have anyone else added anything after removing the tank?
