Adding speakers in 29.5 hunter cockpit
A
Arnon Koren
Looking for the best place to add 2 speakers in the cockpit on 29.5 hunter boat and what is the best way for the electric lines to enter inside the boat. Thanks.
Arnon Koren
A
Andy
Wish I had a pic
I made wooden speaker boxes out of 1 x 6 boards. Three 6x6x1 pieces glued and screwed together (stained teak finish), with two of them having holes cut for the speakers. I then used a plastic mounting doo-hickey that used a thumbscrew clamp and attached them to the stern rail next to the stern rail seats. I ran the wires out of the locker hatches. Viola-no holes in the fiberglass. When not in use, I loosed the clamps, detached the speakers, and set them in the lockers to prevent theft or excessive weather damage.
I got the idea from someone that used teak winch pads in a similar fashion.
If I find a picture, I'll post it.
jtm
stantion mounts!
I have H28.5 and am considering spkrs in the cockpit- but don't want to cut into the "T" walls. Saw these stantions mounts - about $80 each and could mount on the angled stantion of the rear cage where it rises from toe rail towards lifeline connections- thereabouts.
see this URL ( all on one line in browser)
http://www.thrillaudio.com/Car_Audio___Electronics/Speakers/6_5____6_75__Car_Speakers/Boss-MRWT65-BOSSMRWT65.html
# 200W power handling peak
# 40oz magnet structure
# 4-ohm impedance
# 80Hz-20kHz frequency response
# 90db SPL 1 watt/1 meter
# Poly injection cone material
# 1" aluminum voice coil
# 1" mylar dome tweeter
# Plastic grilles
What do you think???
