Venture 21 speed freaks
Ok all you speed freaks, here's how it happened.There were four of us involved, and we were all in college at the time; As kids we had grown up with a variety of high performance dinghys, Lasers, Fireballs, I-14's, even a Dutchman or two. We all new what it would take to get a Venture 21 to go fast. (Actually it might have been a Macgregor-21,It had a masthead rig, with the jib going all the way to the top.) First we beefed up the rig. Better chainplates, thru-bolted with good backing plates, and we reinforced the glass where they mounted.We made up new shrouds, and stays, from the next wire size up. We added a split adjustable backstay, and then discovered that we could bend the boat when we pulled it tight. So, we expoxied in some additional stringers inside the length of the hull, also under the fordeck.(It oilcanned a lot when we stepped on it. We raked the mast back a bit, and torqued in some prebend. We completely replaced the rudder, gudgeons, pintles, everthing, with the rudder from a Flying Dutchman. It was lighter, and more aerodynamic. (It turned out to be a bit too small) We sanded and faired the swing keel and gave it a coat of teflon paint. We added a vang, a cummingham, outhaul, etc. All of the things we were used to. A regular Hummingbird fishfinder/speedometer was mounted on the transom like it was a fishing boat. (it was cheap.)On the day in question, we were out messing around when we discovered that we were at the wrong end of the lake with some thunderstorms on the horizon. We came around, popped the chute for a dead run back to the launch ramp. The storm caught up to us first. When the gust hit, the boat pulled up onto plane. We had been going about 5-6kts, but when we got up on the bow wave, we rapidly accelerated to 9-10. Our apparent wind went forward, and we had to radically steer down to prevent a knockdown. When we steered down we pushed over the bow wave and surfed down hitting 15-16 kts for about 5 or 6 seconds before we slowed down when moving up the next wave. All four of us had moved back into the rear of the cockpit to help keep the rudder down. This went on in phases for about 5 or 6 minutes before we lost contol. We took a knockdown, we got the boat back up and took another knockdown. We got it up again, but when we overcontrolled (trying to prevent another knockdown) and took a pole down broach. We broke the mast ring where the pole attaches, and had to drop the chute. We came in under a reefed main. I estimate that the wind was around 30kts with gusts to 35-40 kts. In my opinion, we would have blown the rig if we had not modified it somewhat. I don't remember if the keel was up or down. I do remember that the backstay was on hard, and that the Chute was tweeked down hard on both the sheet and the guy.We had hoped to take the boat somewhere and race PHRF, we thought that we could beat the 253 rating. But, the sails were just too blown out for close tacking, and we weren't going to throw any more money at it. We ended up selling the boat later that summer, we all needed the money for college. I've always wondered whether or not we could have made it really go with just a little more work. (And some new tape drive kevlar sails)Barry
