Adding Gas Spring to Rodkicker
Oct 5, 2015
80
Hunter 33 33 Halifax
I have a 2007 Hunter 33. Has anyone added the optional gas spring to Rodkicker?
If so can you provide information/specs and where to purchase?
Thanks,
May 7, 2012
1,574
Hunter e33 Maple Bay, BC
Thanks,
Make and model of your particular Rodkicker would help us help you.
I purchased a gas spring kit for my 2012 Hunter e33 from Vela Sailing Supply. It is a Selden Type 10 Normal p/n SEL308-070-03. I believe that all the Types come in 3 different pressures.
https://www.velasailingsupply.com/selden-gas-spring-kit-rodkicker-10-normal/
Specs are here for the Selden Type 10 Rodkicker
http://www.seldenmast.com/en/products/pdfdownload/__file_excerpts/595-808v7-E-68-70.pdf.html
JRacer
Aug 9, 2011
1,382
FYI, I found that the standard spring was not stiff enough to hold up my First 310 boom with the main on it. So, I went with the next level stiffer.
Oct 29, 2005
2,366
I bought this gas spring from Selden for my RodKicker, "Replacement Hard Gas Spring P/N: 308-071-04 (1.2kN)".
When it fails after some years, I go with 3rd party gas spring:
sgs-engineering.com
Rodkicker 3rd party replacement
GSV14-250 Gas Spring
LOA: 588 mm
Cylinder Dia: 28.5 mm
Cylinder Len: 312 mm
Rod Dia: 14 mm
Rod Len: 252 mm
Compress Len: 336 mm
End Threads: M10 L~12 mm
Gas Spring Force(N): 1200N
Ken Y
