Adding Depth (deadfall) to anchor locker in 35.5 Legend, 1990
Aug 15, 2013
193
Hunter 35.5 Legend 003 San Carlos, Sonora, Mexico
Has anyone modified their anchor locker to increase the deadfall so you can put an adequate amount of chain/rode and not have to sit there and sort/adjust the rode on the intake? I really need to be able to deploy my bow anchor from the wheel. I have a switch at the helm, works great but if I don't add some depth I will forever be required to send someone forward on the intake (bringing it up)
I was thinking of just carrying down the anchor pit, while I lose about 1 Ft of legroom in the Vberth, it will be well worth it. What I don't know is the structure behind it. I think we have an internal "pan" to cut through and then all we see is the exterior hull. I would glass in a new wall giving me the depth I need and a drain to the outside at the new depth, which is above the waterline. Add a cone of some type to keep rode from piling. I try to never assume anything, so I thought I would seek advice...
Any thoughts, opinions would be appreciated. Thanks in advance.
JamesG161
Feb 14, 2014
7,815
Hunter 430 Waveland, MS
You Anchor Locker is design to keep you boat water tight.
I would never modify that design.
There a few post on the "Pile up" the Cone idea seem like a good one. Use a Traffic Cone might work.
Jim...
Dec 14, 2003
1,438
Hi Steve, I have a 34 and I have done that mod and kept the anchor locker such that the boat is still water tight. Attached is how I did it. FYI on my 34 I did not loose any space in the V-berth ! Hope this helps. Good luck
Likes: heritage
Aug 15, 2013
193
I have no question I have the skill sets to modify the locker and keep the boat watertight. The depth of the locker is < 12", it is just not workable for someone that cruises (sea of cortez) with it. The locker would not be deep enough even with expansion ( I estimate to be at least 18" deeper and would start at the first lateral support in the locker (where wiring comes out of-keep that little 3" self and go down from there., I would make a cone for it. As far as added weight, adding 8-plait on a splice is no big deal. Adding too much chain for the design might be... but I sit well on the waterline, pretty even athwartships and bow/stern.
Aug 15, 2013
193
NICE JOB! Thanks for sharing, Exactly what I was looking for, I'm sure that while our boats are a little different, not too much different. I suspected a pan liner there. Just trying to be thorough as taking stuff to Mexico - list has to be complete as possible. I single hand a lot-setting an anchor in a difficult situation can be disastrous if you have to leave the helm and go forward - at the least, challenging.
Not too long ago my seawater intake clogged (solid clog-disassembly of intake was required) right at the mouth of an inlet to the bay, fortunately I was able to deploy the jib and sail out-but an anchor to stop movement to the lee shore should be a plan B....
