Adding Axle to Mac25 trailer?
90
Macgregor 25 Santa Barbara, Ca.
Has anyone added an axle to a MacGregor trailer? Is it a good idea? $200 + $150 for tandem fenders. Didn't like the way the trailer bounced all over the freeway when I hit a little bump and hope the extra axle would help with that. I have also seen some advice that a tandem trailer is a must for long hauls. Any suggestions or opinion would be appreciated.
May 4, 2005
4,062
I know many folks have done this on the 26's. the 2nd axle was put behing the stock one. -on my stock trl I move it back 13" with good results.
Tom26M
Agreed
When I owned my Macgregor 25, it scared me to tow the thing. But I learned a few things. The OEM axle was too small and you could actually see the bend in it as it struggled to support the weight of the vessel. Adding another axle would have been my first line of trailer mods. The second axle would definitely be a larger diameter if possible. Another addition would have been trailer tires of a larger size (here again, if possible). A good 15 inch set of tires.
Maybe all this would have been an overkill but in the case of trailering 'less is not more'.
Trailering around with my M26 is easy and adequate for the job (trailer that is). Mostly because ballast can be dumped before trailering. On a 25 it must be added to the weight load on the trailer.
Tom
caguy
Sep 22, 2006
4,004
The single axle has been fine for me. I don't travel in excess of 60 mph. I've towed as far as Tahoe with no problems other than the bolts on the fenders working loose. After adding a second nut problem ended. When I tow I am careful especially on the 405 around Wilshire and Sunset overpasses I slow to 45. I keep an eye on the back of the car in front of me as an early warning that a dip or bump is coming. I don't tow with the motor on the boat. I have seen mod where a motor bracket has been added to the front of the trailer to reduce sway. When I load the boat for a trip all of the gear goes into the V-berth. I also have a 3'' ratchet strap with which I strap the bow down to the frame. That really made a difference in controlling the bounce. I shackle a short 5/16th cable to the bow and trailer because I don't trust the webbing on the trailer winch. The exposed section seem to last only about 6 months. I cut off the rotted section and tie a knot with the strap, I have had the stitching break loose. The only other caution that I can think of is to watch the front trailer tongue they seem to rust from the inside out. Speaking of rot I had to replace the bunks, they too showed no signs of rot until one broke. Fortunately it was while loading the boat at the ramp. We re-floated the boat and found a Lowes where we replaced them. Took less than two hours.
Oct 24, 2008
424
Macgregor 25 (1984) Wildomar, So. Cal.
I'll have to add a few of those ideas to my trailering, Frank.
One additional thing I do is run a line/strap around the cockpit and tie it off on the traiiler.
Why??
When I first got her, I had to remove her from the POs yard - going over the bump of the curb (at a slight angle, since the road was narrow) caused her to shift to one side. I had to stop and use a floor jack at the rear of the boat to repositiion it There was no keel in her at the time, but it was scary enough for me not to take the chance of that happening again.
I noticed the same thing when moving a Mac21 recently - it too had shifted a bit on the trailer.
I do not know if this is a common problem, especially if you go over a large bump of some kind, but I feel a bit safer kowing something additional is holding that boat down.
caguy
Sep 22, 2006
4,004
Why??
I do the same MrMikey, with the dock line, only because if the trailer and truck separate at 60 mph I hope to find the boat and trailer in the same vicinity. I like to rest the keel on the trailer when traveling to take the weight off the bunks but I don't give the cable slack because I want the weight of the keel to help hold the boat down over bumps.
Mick
Jun 11, 2009
140
Macgregor 26x Oklahoma City
I like many others have had the concern of pulling . I have a Mac 26S . I purchased it in the spring in Dallas, and towed it up to Oklahoma City. The previous owner did not tie it down I made sure it had two 3 inch cargo straps.
When I got home I replaced the rotted nylon strap for the bow winch with wire rope. Plus I added a nylon strap on the bow as a back up.
That being said. We live about 5 to 6 miles from the lake, the road is not the smoothest , but in good condition. I noticed that the trailer tongue , kept bouncing against the ball hitch. Then I came across this thread.
This AM I went down to a local trailer dealer & repair shop. He has been in business for 28 years , and has a great reputation for being honest.
Here is the info I got off of him.
First >the tongue weight should be 10% of the weight being towed. I figure the boat for 1600 lbs ( dry) , and the trailer for 400 lbs. That means I should have 200 lbs resting on the ball. I took a bathroom scale out ,with the tongue jack resting on it , I read 100 lbs.
Second > Options best is to install a second axle total here would be about $700. Next is to add weight to the front of the trailer, Lot of steel / lead. Or you can move the existing axle back a bit , which will put more weight on the tongue.
I will do something this winter, probably use the move axle option. I do have about 30 lbs of weights that I can put on the tongue as an experiment , not perfect but hope to improve a bit.
I sure am glad this thread popped up. I thought I was the only one to have this problem.
Aug 26, 2007
90
Thank you all for your input. I will take some measurements this weekend and do some research before I decide what mods I will do. I really think the second axle is a must since I will be towing on CA. wonderful freeways. I will keep you all posted.
Fred
Sep 27, 2008
517
Catalina 28 mkii 745 Ottawa, Ontario, CA
You might want to consider an equalizing hitch. Although I have a double axle I would credit the equalizing hitch with keeping the ride smoother.
On the subject of a strap, I have a ratchet strap that runs up from the end of the trailer over the cockpit (behind the rear cleats). This holds the boat down and also provides a forward force. This is very helpful when I load the boat on the trailer. Once the boat is on the trailer I tighten the strap and then it takes a much lighter "bump" to move the boat forward on the trailer against the bow stop. After the bump I have to retighten the strap and the boat stays nicely in position.
Aug 26, 2007
90
MacGregor did not build the trailer with CA. highways in mind. On flat straight roads it works great. My HD2500 pickup is plenty of truck to tow such a light load. and a equalizing hitch would only help if the tongue weight was too much for the truck. An anti-sway hitch would definitely help with sway, the bounce I believe is due to the poor distribution of weight on the trailer and not enough suspension travel. The short stiff springs are like pogo sticks. What do you think?
Timo42
Mar 26, 2007
1,042
Venture 22 Marina del Rey
Tim, use a strap at the bow eye, another across the cockpit at the rear of the trailer, stay off the 710 fwy and use some penetrating oil on the springs to soften them up, they may be rusted solid. Weight in the bow will help. Maybe come down and look at trailers at the mast up storage at MDR, see what others in the area have done. Frank and Duane both have their boats down there. We're going out next weekend at least one day,
Tim
Aug 26, 2007
90
Hi Tim. Thanx for the invite. I was supposed to tile the Bathroom this weekend but was sick as a dog and didn't. So I will be doing that. I would rather come down and sail. Don't give up on me.
I planed on getting the trailer out from under her, will have to wait now. When I do I plan on moving the spring hangers back, add some guide rails and getting it painted or Pwdr coated. I will pull the springs apart and rebuild them. They did look like they were sagging, the hangers were almost letting the eye touch the frame. . I keep forgetting I have a truck that can handle some tongue weight and am sure the trailer was designed to let small vehicles tow. So moving the axle back (moving the weight forward) will help. I am definitely going to strap her down.
Timo42
Mar 26, 2007
1,042
The bathroom isn't going anywhere,:bang: why not promise to do it Labor Day, you aren't going to want to be on the road then anyway.:dance: We may be riding on the beach in Oxnard Saturday though.
Aug 26, 2007
90
Where can you ride on the beach in Oxnard? Have been putting it off for 10 months. And i want to relax for labor day. I have no time for the extra stuff nowadays.
Aug 26, 2007
90
I wish I could tile my whole boat. It would be like new by now.... TIMO did you go out this weekend? Did you ride? I worked on the foil design for the rudder. I am going to change the chord, adding an inch and balancing it. The foil is based on NACA 0012 at a 13" chord with the last 10% cut off. I drew out an airfoil on a CAD program. I used a 10" chord and NACA 0012. (it made it easy to move over a decimal to get the %) I can now use that same drawing and change the chord and the correct size at 30% for that chord and print out a template. Going to try to engineer a kick-up system too. I will have some sketches soon.
Dec 31, 1969
101
I just bought a Venture 25, 1975 model with what I assume is the unmodified 1975 trailor. I am pulling it from Louisville Kentucky to southern West Virginia. Am I in trouble?? Reading these posts about bouncing boats and second axles makes me worried. What should I do? I could pull my Hunter 170 from here to the moon without so much as a second thought, but now I am thinking again!
Aug 26, 2007
90
I think you will be ok as long as you completely inspect the trailer. Strap down the Boat. Make sure the tires are in great shape. And drive safely. Most of my concerns on this thread are because of driving conditions, rough roads etc.. I towed my 81" mac25 over 40 miles without strapping it down (I did not know I should) And made it home with only losing the Hatch (rails fell off.). Just be smart and you will be OK. Good Luck.
Timo42
Mar 26, 2007
1,042
Tim, how's the smoke near you? Didn't go riding, people I was going with are horse haulers, they spent Sunday evacuating the fire areas, the fire is going slow enough they didn't need to call me, but one is on a farm in the Soledad mandatory evacuation area I talked briefly with her this evening, fire 6 mi away, think happy thoughts. Borrowed my friend's 30' Islander to go out with family Sunday, no wind, but for once I'm not complaining. Plan on borrowing it again this Sunday. Qoheleth, don't forget to repack the wheel bearings before you go, and take it slow. Tim
Aug 26, 2007
90
TIMO, That 30' Islander is a sweat looking sailboat.
Smoke is good tonight. Last few days were bad. Haven't been called out for evacs. this year. Most people with horse leaned from the last couple of years of fires in the SCV, to be prepared and have a good plan in place.
I am just so tiered of this heat. Want to retire and move to the coast.
Qohelth: Make sure everything on the boat is secure. I still miss that hatch.
362
MacGregor/Venture 25 Winthrop Harbor, IL Drummond Island,MI
same boat and trailer
Like previously stated, pack bearings, check tires for damage and pressure, don't load the boat heavily. Place spares and/or equipment in V-berth. No engine on transom. Tie/lash shrouds or anything loose. I place a racheting strap across the bow to the trailer, keeps it from bouncing. If you pull in the rain, interior will get a little wet. I've pulled this thing 1000's of miles and have yet to have a problem, but then I believe an ounce of prevention is worth 100 lbs. of cure:)
