Bilge Pump Placement
In the bilge, below the floor board between the nav station and the galley cabinet there's a 2"x3" (approx) sump. Ideally, you'd put it in there. When I replaced the pump in mine I couldn't find one small enough to fit in there so I placed it just beside it on the center line. This seems to be the lowest area of the bilge, but not by much. The problem is that the bilge has to be almost full before the pump will draw so it's not much good for clearing the miscellaneous water that collects there.Maybe if you could find a pump with a hose for an intake, you could run that into the sump and then put a non-float automatic switch next to the sump.(BTW, I use a wet-dry vac to dry out the bilge; it works pretty well.)
