Adding an axle
L
Lee
I have the standard single axle trailer that comes with the Hunter23. Has anyone added a second axle? If so, what was the approximate cost? How difficult/easy was it to do? Thanks Lee
Jun 2, 2004
3,673
Did it on My 23.5
Picked up all that was required from Champion Trailer. Call them and they will be very helpful. http://www.championtrailers.com/ SINGLE TO TANDEM AXLE CONVERSION KIT CONVERT YOUR SINGLE AXLE TRAILER TO A TANDEM TRAILER WITH THIS KIT. KIT WILL ACCEPT 13" OR 14" TIRES WHEN ORDERING, YOU MUST IDENTIFY YOUR CHANNEL OR BOX TUBE FRAME SIZE KIT PART# 3257 $565 Has everything you need less the other two rims and tires.
A
Arturo DeVitalis
Bent Axle
I am second owner of a 94 Hunter 23.5 that came with the original factory single axle trailer, which apparently could not support the weight, as the tires are sprawled out and the axile is bent. Going to attemt to straighten the original axile and add a second. in the past 4 yearsI've trailerd over 3000 miles in this condition and it was scary. It was said that hunter stopped using the single axile trailers after 1994, but not certain if this is true. Whatever, I'm going for doubles.
Jun 2, 2004
3,673
Forget the Original Axle
It is likely bending because it is rusting.
