Dean Strong
I want to add a line clutch and winch to the port side cabin roof of my 1990 Hunter T30, so I can add a second reef and a spinnaker halyard. The problem is, there is no access through the roof liner to add the line clutch. There is an access panel for adding a winch, and one further forward for the line organizer, but there is not nearly enough space to squeeze and hand through the panal into the space between the roof and liner to place washers and nuts or a backing plate for a line clutch. They can't normally be held with just wood style strews, can they?Should I just cut through the liner with a Dremel or something, and then add another access panel? Anybody done this to a smaller mid-sized Hunter?
