Adding a Forespar motor hoist (Nova Lift) to a C-310
11,772
Just finished adding a Forespar motor lift to my C-310 to lift my Nissan 4-stroke. I am very impressed by the build quality and ease of installation. The only thing I changed was to upgrade from a single block to a double to make it easier to lift. If you buy a forespar be warned that although they supply the sheaves to make it a double the included line is not long enough. I wound up spending an additional $80.00 on a Harken block and some 3/8 Sta-Set line. This thing makes it very easy to lift an 82lb four stroke and I can launch and retreive it myself with no additional help....
MarkZ
Nov 5, 2005
119
Hunter 49 Green Turtle Bay: Ky
Great looking job...
Hi Acoustic, That's a good looking job on your motor lift. Do you clamp the motor to another mount after you hoist it, or does it just hang from that lift?
Feb 6, 1998
11,772
It's mounted to a motor mount
From West Marine. The mount is white plastic for a 1" stern rail. Once it's on the motor mount I release the line on the lift and leave it loose..
