Location of padeyes for Assym. Spin. on 310
Hello Paul,I have to agree with Ray, I am seriously thinking of adding the blocks in the same set-up you have.My concern for using the footblock for a spinnaker would be the lead on the loaded sheets. Does this cause the sheet to wear on the cheekplates?In the drawing for my Catalina, the padeyes for the sheets in the optional spinnaker package are located about 1 1/8" inboard and about 22.4" forward of the stern pulpit flange, i.e. forward of the primary winch.I have to be honest, I have very little experience with spinnakers. I am looking at developing the capability because I want to reduce from a 150 genoa to a 135 or maybe even a 110. The 150 is a bit too powerful for the wind off Halifax here most of the Spring and Fall.I am not even certain I would keep the 150. Definately not, if I install the Asym. spinnaker.Thank you for sharing your handiwork. It is much appreciated.RegardsChris
