See Photo Forum
Dick,I installed a Raytheon unit two years ago on my 26. I pretty much documented the installation in the photo forum. Ron sent me his pictures and it was a big help. You almost need to install from the port side because of the motor well. I had remote controls for the motor on the starboard side already, so there wasn't any room any way. The mounting post unscrews, so if you are using the swim ladder, you can get it out of the way. We have never bothered to do that though as it doesn't take up much room.I ran a sperate breaker for the power. The autopilot will be a large current draw, and you would want to be able to turn it off. You could install it with an inline fuse, bur then the deck plug would always be hot. If you get any moisture under the cap, it could cause a short or run your battery dead.Do you sail on Red Rock Lake? We bought our boat from Sail Iowa, and used to sail there. We have sinced move to Wisconsin.Mike PajewskiH-26 "Loon"
