If you use any glue rated for laminate gluing, your stress will be distributed along the wood laminates. Notice the alternate colored laminates. That is a high stress design.
Here is how mariners have sealed their woods for many years.
https://en.wikipedia.org/wiki/Spar_varnish
About 3 coats of SPAR VARNISH, with 120 grits sanding between the coats will seal wood/glues from marine environment and provide the most beautiful finish to show off your tiller.
Jim...
PS:Additional support at the rudder tiller junction as mentioned by others would be good. Just remember to "spread the stress" (like washers do) if you can.
Jim...
