Acetone a safe cleaner?
Jul 13, 2010
1,100
Precision 23 Perry Hall,Baltimore County
The boat Iust bought, rubrails are in good physical condition but are badky scuffed and dirty. A lot of scrubbing with tile cleaner ( with bleach in it, i can tell by the damage to the rag), is yielding poor results. I plan to compound and wax the entire hull ( good thing im retired), is acetone good cleaner for hull and rubrails or is it damage?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Is it metal or rubber? If metal acetone is OK in my opinion. If rubber I would not use acetone as it will degrade the rubber, reduce its ability ro resist scuffs and shorten its life. for rubber, I would use the softest, non-abrasive cleaning materials like dish detergent, etc. Try these tips: 5 Ways to Clean Rubber - wikiHow
Likes: JamesG161
I used to use acetone, for fenders and rub rail. I learned from a dock mate how much easier and better paint brush & roller cleaner is. Give it a try.
Likes: Leeward Rail
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
If the rub rail is vinyl, I've had good success with LA's Totally Awesome Cleaner Degreaser. Sounds cheesy but it works.
Mar 20, 2015
3,304
C&C 30 Mk1 Canada
Is that a brand name ? What is the specific product you use ?
I have long used acetone for black rubber window seals when they are heavily oxidized and grey. If you put a small amount on a rag, and wipe... it eats the top surface and removes the oxidation of the rubber.
It evaporates quickly if used that way.
Notice i say "eats" ? If used too much it will damage the rubber (and other things).
Acetone is used during fibreglass and gelcoat repair, but if left in contact with gelcoat, it will dissolve it.
Best to use a milder cleaner and use acetone in extreme cases.
  • Helpful
Likes: JamesG161
Apr 8, 2010
2,232
Acetone works fine, but it is a very strong solvent. I usually use lacquer thinner nowadays - not as aggressive and it's not as hard on your hide. Still, wear vinyl gloves.
Likes: Leeward Rail
Mar 20, 2015
3,304
C&C 30 Mk1 Canada
Definitely ! Solvents are nasty for many reasons. MEK, Acetone, Laquer Thinner.. Brake Cleaner... It all gets absorbed into your skin and is very very nasty to varying degrees.. Wear gloves but beware that some solvents eat different gloves. Read the MSDS.
JamesG161
Feb 14, 2014
8,005
Hunter 430 Waveland, MS
@sail sfbay Nice cleaning link except for Simple Green.
Simple Green or Ammonia is not allowed on my boat.
_______
Acetone is very flammable. I would test spot it first.
As others have said.
Dangerous around other boat materials.
Not my first choice.
Jim...
Likes: Leeward Rail
No, it is the description of a product. I got mine at ACE Hardware in the States, Home Hardware here in Canada, or Canadian Tire.
One uses it to clean paint brushes and paint rollers.
And stuff on the boat.
Likes: Leeward Rail
Mar 20, 2015
3,304
C&C 30 Mk1 Canada
No, it is the description of a product. I got mine at ACE Hasrdware in the States, Home Hardware here in Canada, or Canadian Tire.
Looks like the version sold in all those stores is made by Recochem, but sold under different names like "Solvable"
Edit: here is the MSDS:
Brush and Roller Cleaner
Mostly Stoddard Solvent/White Spirits with a small amount of Toulene and acetone and other nasties throw in.
7,581
Have you noticed any deterioration of the vinyl fenders over the years ?
Paint brush cleaners smell like they're not too hospitable to anyone or anything.
None whatsoever. They look clean and shiny, no wax needed. Been doing this for a decade or more. Still have fenders I bought in 03, 04 & 10.
You want nitrile gloves
Jul 13, 2010
1,100
Thank you for all the replies folks, I knew I would get a lot of info here.
Mar 20, 2015
3,304
C&C 30 Mk1 Canada
A suppliers safety sheet we had at the shop said that nitrile is NOT recommended for acetone.
I will do some web searching and see if i can fine a chart.
Also.. Not all disposable nitrile gloves are the same.. Reputable suppliers help. All depends on what you are doing.
Likes: sail sfbay
Mar 20, 2015
3,304
C&C 30 Mk1 Canada
found one that discusses nitrile glove compatibility and use recommendations:
Not good for acetone...
Edit: here is a glove chemical resistance chart
