L
Lee Hadjiosif
I decided to add an accumulator tank on my 310 to eliminate continuous pump operation. I would like to know if the smaller type tanks(about 1 qt) are adequate or if I should go for the larger 1 or 2 gallon type. I also can't figure out where to get the same type of rigid wall poly piping and fittings. It looks like about half inch OD rigid wall PVC but West Marine only carries the 15mm type. Thanks, Lee.
