Accual height of mast top
35
Freedom 21 Forked River, NJ
I have a 1984 h31. The specs say the mast height is 47 feet. Is that true and is that the hight above the water line or from the mast step. I will be transiting the ICW this spring and need to know my limitations. If 47 feet is from the water line then what would be an acceptable bridge height that I could expect to clear with out any possibility of a mast strike.
MABell
Dec 9, 2003
232
Hunter 26 Orygun
Safe height - slightly over 47 feet
Sorry I couldn’t resist. I googled “Bridge height on the ICW” and the responses I got showed a minimum height from 62 to 65 feet. I’m a west coaster, but I would assume there are many side trips to take off the ICW that would put you in less clearance. Naturally, you will have charts of the entire route that you will take – right? All the bridge clearances are on the chart.
Aug 9, 2005
825
Hunter 260 Sarasota,FL
Post this in "All Sailors" forum for closer guess
A quick trip to the boat would get a DEFINATE answer(which you'll need!). Tie a tape measure to the main halyard(or mark & measure the halyard) and just add the dist to w/l and figure in masthead gear/antenna. Just did this on our 26' and came up with a suprising 42.5' (ant top to w/l) which is now clearly displayed on the mast. Good luck and safe trip. Michael
BobW
Jul 21, 2005
456
Hunter 31 San Pedro, Ca
Measure it!
Don't trust a spec sheet.... my boat got a new rig about 10 years ago, and there's no guarantee it's the same dimensions as the original. Cheers, Bob s/v X SAIL R 8
