If you access the knowledgebase through the main site it shows you readily if there is info for a particular boat. There will be two numbers separated by a slash and the number after the slash indicates how many items are available.
http://sbo.sailboatowners.com/index.php?option=com_mtree&Itemid=257 then select S2, you can access the info.
Bob
Bob
