oday 28 [pump
JOE. In my 28 85 the fresh water pump is under the sink on the right side. I bought a new pump a few years ago. I bought a Shoreflo pump at west marine then it was about $135. its simple connect the two wires 12 V which goes to the circuit breaker, connect the incomming water line . to the pump to the strainer which is part of the pump the outgoing side to the water line Put the circuit breaker on and check for leaks the pump will continue to run until it builds up the pressure and should shut off, Just a note donot used wire nuts to connect the 12 V use the but connectors marine grade Good Luck ,its simple fRED Pierce
