Accessing / Replacing Raw Water Impeller
May 15, 2022
12
Hunter 456 Portland, CT
I purchased a 2002 Hunter 456 recently and spending the next few seasons getting to know her. This past winterizing experience has been a good education. I'm now stuck at the impeller. The raw water pump on my Yanmar 4JH3-TE is tucked behind and under the alternator and facing aft up against the port bulkhead in the engine compartment. Needless to say, I can't see it and can barely get my fingers on it. Does anyone else have this configuration, and how have you managed? Thanks, SS
Jan 4, 2006
7,424
Any chance you can supply a few pictures ?
Sounds like the sort of thing that makes one ill at first sight.
Dec 25, 2000
5,950
A bit different model boat here, but the sea water pump on our engine is in the same location. Replacing our impeller was pretty easy. Four machined screws hold the pump cover on. Wiggle the old impeller out with needle nose pliers, but remember the vane rotation. Clean the pump face of any old gasket material. Install the new one with the correct vane rotation using the lubricate supplied with the new impeller.
How many hours do you have on the engine/impeller? Does it really need replacing? Purchased our boat in 2002 with about 600 hours. Replaced that impeller last year with about 2,200 hours on the engine. The old impeller looked just like new, so will keep it as a spare.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Same issue on my Hunter 386. Had to disconnect the transmission and front motor mount, jack the motor up and rotate the alternator to get access to it.
  • Wow
Likes: Semper Sailor
Jan 4, 2006
7,424
Same experience. Replaced old impeller at 1,000 hours because I had it apart for an inspection. Looked like new and saved as a spare.
Likes: splax
Jun 1, 2009
1,860
Hunter 49 toronto
I wrote up a modification. It’s posted on the site. After implementing this, you’ll be able to change your impeller in 10 minutes.
The Yanmar design was awful. I suggest you look into the mod
May 15, 2022
12
My engine has pretty low hours...~360. Hopefully, I'll find the impeller looking great, but I need to know... :)
May 15, 2022
12
I think you're right, Artboas. I'm going to have to "dig it out" and I might as well modify while I have the peripherals removed and disassembled...
Jun 1, 2009
1,860
Hunter 49 toronto
You will not regret doing this.
Its literally a day’s work, and $300. And you’re done.
Try to imagine changing the impeller (as it exists), off the dock in a seaway. Simply not possible.
Pm me if you need help
