Access to the impeller on a 456
86
Hunter 456 Port Canaveral
On my 2002 456 the impeller is on the non-working side of the engine (4JH3-TE) against the bulkhead, facing back and behind the alternator. It is nearly impossible to reach. Has anyone found a reasonable solution on how to access it? I want to solve this before we head out to the Bahamas. I can't imagine trying to change this impeller in rolling seas on a hot engine.
Thanks
KD3PC
1,069
boatless rainbow Callao, VA
remove the whole pump, and change the impeller
use a mirror, old mechanics trick, but tough to get your directions straight
access hole made that will allow you to get to it correctly
best of luck, and it will result in at least one broken finger, perhaps two, if you do it in rolling seas, been there done that.
Oct 24, 2011
278
Hunter Passage 450 Lake Lanier, GA
Thanks
I am the same situation with my 450 and was intending to post about this.
I have seen some owners install an access panel in the shower, but my boat does not have one:cry:
Jun 1, 2009
1,852
Hunter 49 toronto
Two things can help you
Thanks
On the newer Yanmar impellers, they have threaded the shaft. You can make/buy a small tool that will aid with the extraction. Only works on genuine Yanmar impellers.
Once you have the cover off, replace it with a Speedseal cover.
I can't imagine what Yanmar was thinking when they put the water pump where it is. On the 49, its even harder to access
Dec 2, 1999
15,184
I do not know the exact setup on your setup but we cut an access door in the port side of the engine compartment. This allow me to get a set of angle needle nose pliers into the access area to remove the impeller.
We also replaced the impeller cover with a Speed-Seal. This makes getting the cover on/off much easier. Speed-Seal also have some new teflon washers to make your impeller last longer.
PS: Our engine is the 3JH2E (similar access to impeller)
Mikem
Dec 20, 2009
823
Hunter 466 Bremerton
On my 466 I have to remove galley doors, galley shelves, access panel, companionway stair assembly, and then I stare at the rear mounted behind the alternator water pump impeller. The thought of dropping a screw under the engine is unnerving. I will have to take another look at removing the whole pump and then changing the impeller. I cannot imagine doing this in any kind of a sea state with a hot engine. Geez.
Apr 22, 2001
497
Hunter 420 Norfolk, VA
Thanks
I have several friends with 456's.
Although it is possible to lean over the engine to replace the impeller, it is very difficult to do.
The only practical way of dealing with this problem is to cut an access panel in the shower as Bowedtoothdoc mentioned.
Mar 30, 2013
11
Hunter 456 passage Dalhousie
I changed the impaler on Ceilidh, Hunter456 passage center cockpit 2003. Pain in the ass... First remove the belt and alternator. Second remove the 4 screws on the impaler cover. Third you need an impaler extractor and it is far and difficult. I never understood how people making a boat would not think of a better plan and configuration. The option of cutting an opening in the tub sounds ok but you are going to be far back and im not sure the access will be good.
Jun 5, 2004
138
HUNTER 450 Rockhall MD
On my 2000 450 I had a panel installed. Don't remove the pump you have to take the mount out. You can change it if you take the alt off and I use a needle pliers that have a round end , from MA C tools.
Jun 1, 2009
1,852
Hunter 49 toronto
Really, really bad design
If you guys think you have problems, on 49 the engine is mounted sub-floor.
It is a full day's job.
I am going to design & build a custom tool for this.
My goal is to have impeller change over in under 30 minutes without pulling alternator, etc., etc. I think, based on preliminary design This is possible.
Stay tuned ......
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
WOW
Thank goodness my 07 H-36 is so easy to change the forward facing impeller cover and my stairs remove away to work on the whole engine.
Another good reason to stay with my H-36 which we love and not go bigger,so easy to work on most anything and well designed model for storage easy sailing and just all around cruising,my P Gen iseveen easy to work on.
I did change the engine oil and filter and Gen oil and change the impeller yesterday in less than an hour.
Good thing we have this forum to help out with these :eek: repairs.
ick
