I'm re-locating main sail traveler in the cockpit of my First Series 32s5. To adequately mount a turning block and cam cleat I need to access the cockpit area horizontal surface from below. Before I cut a hole in the interior liner in the aft cabin and head I'd like to be sure I can access this area without issue. Both areas are starboard and port of the cockpit step to the companionway and in line with the traveler track mfg. designed space to house the traveler track. I welcome input if you've been there.
