Jim Rice
I had to replace the pads under the mainsheet blocks. But with the headliner I couldn't get to the nuts. So I chucked a fine blade in my jigsaw, put a paperback under it to limit the depth, and sawed holes for 4 inch access plates (the flange on the base is shorter for the 4 inch plates than the 3 inch versions). They fit tightly anyway, but I "glued" them in with some 3M. With the holes, I could then get to the nuts--which didn't exist.Your mainsheet blocks may just be screwed into plywood pads under the cabintop !!!!!So out came the short bolts and in went longer bolts, WASHERS and nuts.PS--You may also saw thru electrical wires to you nav table and galley lights! I did. Whoops.............
