Chuck,That's pretty much how I visualized it. I thought I had seen a Hunter 356 once with both the genset and ac thru-hulls located in the same area as the others (forward of the engine). I'm not fond of the idea of using the shower sump for the ac outlet, thats a lot of water when it is running and would put more load on the shower sump pump than I would want to risk.My manual shows the ac location where my refrigeration unit is, so I expected to go outboard as well on that side. Are you putting in the reverse cycle unit or just ac? Also, I have not been to the boat to measure, but I was curious if the 13.75" height is a problem in that location?I have struggled with the best solution and have finally arrived at the Mermaid ac/rc heat. I don't need ac much, in fact rarely, but heat is a big deal. I looked at diesel fired heating, which is an alternative, but in the long run, we may take the boat south for a season or two, so that finally focused the thinking.Also, do you intend to use the ac away from the dock power? If so, what are you going to use to power the load?Thanks for your help, and promise for pictures. Where did you buy your unit?Dan Jonas (S/V Feije II)
