Grunert System
Kevin: You should get good advice on this here - it has been a hot topic previously. As far as Hunter saying they have had no complaints - I don't think so!!!We have a 460 with the same system. First, I have never seen a draw of 150A when the fridge is running. For our system, max is about 105 when starting, and usually settles down to about 75, 85 if both sides are on. Second, the system should not short cycle like that. When we got our boat, it had many control problems. It works well now - both controls have been changed. In my experience, the system will run for about 10-20 minutes at a time. It even does this at first use, cycling on and off until the set temperature is met. Once the set point is reached, it will run about 15-20 minutes every 4 or 5 hours. (assuming wise use of the doors).Total draw should be in the range of 100-150 A/Hrs. per day. If you live in a very warm environment, you will have higher use. As far as the system in general, now that ours is working correctly, I like it. We actually shut it off at night - it holds temp very well, and run it in the morning which is often when we will be motoring, thus saving on the batteries. If we aren't moving, we run the genset for an hour or so each day.Our batteries have been boosted to about 700 A/H.Our total usage daily varies between 200 and 300 A/H depending on how hard we try. We wanted to be able to go two days without necessarily re-charging, but that doesn't really work because it will take too long to re-charge if we draw to the full 350 A/H available. The answer for us is to run the batteries between 50 and 250. Hope this helps some.
