AC Electrical Problem
6,990
don't breaker a ground
The ground is a safety wire. You NEVER want it disconnected. It provides the path to ground instead of a person providing it.
NEVER breaker a ground wire in AC circuits!!!!!!!!:naughty:
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
hummmm come to think of it Ron and Bill you are right it had not even occored to me about the ground running through a breaker...
while i am standing corrected ...i would also like to know if it is koser to run all grounding wires to the strut bolts as i have found mine ....when i got this boat it was and still is in bad shape but worth the fix given paticense and time ...the prop was almost dust from no anod on the prop shaft ...now i find that the shaft strut is not sound as well ....no ring when it is hit with a hammer and when i started to remove the cutless bearing what was left of it it would flake off at the least little pressure....hope i havent hijacked the thread....
comments please
regards
woody
