Does anyone have thoughts on installing a fresh water backwash into the air-conditioning compressor/s? What I am thinking of doing is installing a three way valve/s as close to the Ac outflow/s through hull/s as possible. Use the fresh water system to feed that valve and pump fresh water into the ac unit/s backwash style through the raw water pump then into the strainer and out the raw water intake through hull. Have two Ac units one forward one aft. Boat in Miami, FL warm water, lots of growth, sits at dock with ac on/off 24/7 to keep the boat cool and dry... lots of cleaning of raw water strainer. I would hope that this would dislodge any growth in the system and having the freshwater sitting there for 10 minutes or kill any sea creatures attempting to attach themselves to the pipes and tubing. Would back wash be more effective than just piping in fresh water close to the intake, fresh water then following the same path as the raw water? One better then the other.Any thoughts? Thank you,Jeffreys/v Mystiko
