You need to do some homework
As Reudi mentioned, you need to know how much you discharge the battery each time you use it. As a general rule, lead-acid batteries shouldn't be discharged past 50% of their rated capacity for very long. If left undercharged for too long, the battery will be irreversibly altered and cannot be recharged.Battery storage capacity is rated in ampere-hours (Ah). In theory, a 60 Ah battery should produce 1A of current for 60 hours, or 20 A for 3 hours. Actual performance is usually not as good.To calculate current draw for any electrical device, divide its rated wattage by 12 volts, e.g. a 12W device like a single light bulb draws about 1A when lit. The worst offendor is probably the anchor lighy, which draws up to 2A and stays on from dusk till well past dawn. To figure the total draw on the battery over a weekend, figure the current draw for every electrical device you intend to use, note how long each device runs, calculate each device's draw in Ah for the entire weekend and add them up, The sum is how much energy (in Ah) you withdrew from the battery and now have to restore with the solar panel.To figure charge time, divide the solar panel wattage by 12V to get the charging current, Then divide the energy in Ah by the charging current and you have the total charging time in hours. Divide by 4 to 8 to get days. The panel gives max. rated current when the sun is perpendicular to it, there are no clouds and the panel is clean. Panel efficiency also goes down the farther away you are from the equator.Select a panel that can restore full charge in two to three days. Otherwise, you run the risk of ruining the battery. A 10 to 15W panel should be fine for casual weekend use, but if you routinely use a tillerpilot and a bunch of other electronics, you need at least 30W.Bigger panels need a charge regulator because they can cook the battery if left unmonitored (please don't ask me how I know this). Water levels in the battery cells should be checked at least once a month.The other alternative is to be frugal with your electrical use so that a 10W panel is all you need. On the odd weekend when you do get power-hungry and draw the battery past 50%, take it home ASAP afterwards and put it on a conventional charger. Sorry this was so long.PeterH23 "Raven"
