Called Interlux..
I called Interlux because I had some questions about Micron 66 which I may switch to.
Here is their answer:
[FONT=Verdana, Arial, Helvetica, sans-serif]
Unless the ablative paint is a copolymer ablative yes they do stop working. The one exception, at least in the Interlux line, is Micron 66 which is not technically a copolymer yet it can be re-activated by washing it and lightly rubbing it with a Scotchbrite pad before launch. You can actually avoid this step and re-activate 66 by actually sailing it a good deal before sticking or on the dock or mooring. One of the cool things about 66 is that it ablates in salt water without having to actually run the boat. This is a big benefit for the dockside/condo boat crowd..?
[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif] [/FONT]
Non copolymer ablatives, at least with the Interlux line up, have a max out of water time of 60 days just as Warren stated. It is important to note that at 60 days on the hard it has lost considerable efficacy, more binders have dried, when compared to 10 days out of the water, less dry binders.[/FONT]
[/FONT]
Non copolymer ablative paints will in a sense "dry out". This means the active binders, that create the "ablative" properties of the paint, if left out of the water long enough, stop working. Storing the boat out of the water prevents the paints from leeching copper and stops the ablative characteristics of the product if left out long enough. [/FONT]
[/FONT]
Copolymers and Micron 66, are currently the only ablative paints from Interlux that can be hauled and re-launched with no loss of efficacy. This is straight from Interlux tech support and applies only to their brand. I would guess the Pettit products react similarly.[/FONT]
I still don't understand why PS or any other articles never mention or add a column for us Northerners that deals wth haul & re-launch. So, if you're out less than 60 days, a non copolymer can still work but it will have lost efficacy. beyond 60 and your really gambling.
[/FONT]
[/FONT]
My power boat was out for 5 1/2 months and the Ablative was dead. Even running her at 16+ knots did not re-activate it..
[/FONT]
