A spotlight alternative
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
I have an old GE spotlight that plugs into 12v. Swiped it years ago from my first power boat that I ultimately junked.
It still works. However, cumbersome to get from stowage, plug in, etc. And limited mobility.
Also have flash and lantern lights, of course, but none that matched the search power of the GE.
Until now.
I bought a Thrunite Catapult V6 LED "thrower" (spot) flashlight.
It can produce upwards of 1,700 lumens, but it uses a trick little spot lens focusing the beam. Non adjustable.
It's a very small light, smaller than most flashlights, slightly larger than a tactical light. Fits in the coat pocket.
And it's rechargeable using a phone style common cord and any 2a phone charger.
Good quality. Waterproof. $75.
And, holy mackerel, the beam.
The thing puts the GE to shame, blasting a spot out a couple hundred yards with easy visibility. Farther with less visibility. They say up to 700 meters.
I can fully illuminate yachts 120 yards from me in the docks. Enough that anyone in the cockpit could read by it.
And I can use it at any time at any location on the boat.
Haven't tried it at sea yet.
Multiple modes, very low, low, med, high, and "turbo", the last mode of which I call "light saber mode".
A very usable tool for entering a new harbor at night, spotting oddities on the sea that you come across, signaling, or identify and avoiding the unlit paddle boarders and kayakers.
1,742
Where did you find this device?
I bought it on Amazon through the Thrunite store.
But you can just google the name and model.
I had previously researched the company and different models ie reviews and flashlight forums, after accidentally seeing a video months ago of a different model while surfing other marine lighting or solar or something.
Settled on this model for size, power, config, rechargeable, waterproof, etc.
Mar 29, 2017
576
Hunter 30t 9805 littlecreek
How about in fog. I have found LED scattered in fog where has halogen kinda punches thru a little better but sounds like a CooL light.
1,742
Don't know yet.
But here is a screen shot of someone else's video. Yes, that's the beam from this little flashlight.
There are vids and reviews etc just do a search.
I didn't know such technology existed in small flashlights. Perfect for a sailor.
capta
Jun 4, 2009
5,012
I have a question. It says single switch on/off but usually these things have to cycle through every setting to go from full power on to off or vise versa.
Does this one do that too?
It's the only thing that makes the 'clamp light' family of lights and most head lights really a PITA.
There was some discussion about that in a thread here - https://forums.sailboatowners.com/index.php?threads/help-me-pick-a-flashlight.184247/page-4
Sounds like they were going to start offering a simple on/off option. @Gene Neill did they retrofit yours?
As for headlamps, I have one from Amazon made by a company named "Luxuriously Smart". Unfortunately it looks like Amazon doesn't carry it anymore, but it works well for me. One press to turn on to full brightness. Press again within a few seconds and it dims. Pressing after more than a few seconds turns it off. Turning on after less than a couple minutes it will go back to the brightness you left it at.
Oct 9, 2008
1,742
On the Thrunite, you hold the button to cycle. But it remembers your last setting the next time you turn it on.
Also, there is a shortcut to "turbo" mode (I call light saber mode), by just double clicking at any time.
Also handy is the button has a blue light on it that turns red when the batt gets low.
I love that it's rechargeable, so no replacing batts. And uses standard phone charger.
Even if in the distant future the batt gets old, a new one is but $10.
Oct 9, 2008
1,742
I took these pics just now.
The small light in my hand, and the beam shooting across the channel onto the yachts 120 yards away.
Those boats are lit up for a party, with this little flashlight.
