Ok are vented loops bi directional in the flow of liquid thru them? I recently hooked up the loop on the boat and filled the msd holding tank with water and flipped on the macerator to pump it out to check the connections for leakage and proper working. The connection on the right side of the loop to the hose from the macerator was spraying some water. I retightened it and tried again and still the same problem but less spraying this time. The vent is a 1'' Johnson one and yes the seacock was OPEN at the time as the water was being expelled from below the hull via the thru hull.
c_witch
c_witch
