A short pleasant first trip NOT :(
294
Yankee Condore 21 Halifax
The only damage being a bit of scratched paint in docking at 4:00 AM in total darkness and my pride :doh:
Let it be known that I am not to proud to admit stupidity!! The other day we went over to the boat with the alteration to the rudder to keep it down. We finished a few minor choirs that had not been completed prior to launching.
I thought it would be nice to motor out from the docks to the ocean so that we could get a feel for the course and time it would take. Our first mistake was not getting OpenCPN up and running on the laptop. It was light out and 5 PM so we had lots of light and new the channel was buoyed (albeit not by the Canadian Coast Guard). This channel has 2 very sharp turns (90 degee's) in it. Well as it turns out I made the first hard turn at the wrong set of buoys. Everything seemed fine as water depth was what it should have been as we motored along. Then the rudder kicked up and depth dropped to 0M. Problem one the rudder dropped back down but only till it bottomed out and resting on the bottom. I didn't want to put the motor into reverse fearing that I might damage the rudder. By the time we got the rudder secured (second mistake) I lightly gunned the motor thinking I was in reverse NOT!, so I drove us aground onto the sand under us. ( It was the keel box ) that grounded at this point. We tried in vain for 10 minutes to back off to no avail.
Ok so we're grounded and the tide is on the out :(. Nothing to do but wait for the incoming tide to float us again then carefully back out. The problem with this being that it was now 6:30 PM and we were sitting in about 22 inches of water. It would be pitch black when the next high tide arrived and the buoy's are not lite up and we don't have a search or flood light aboard. So sasha takes a reading with the handheld gps as we can see what appears to be safe water just 70 feet to the north of us and can see the buoys that I had mistakenly turned on so work out a course to at least get us into deep enough water once the tide comes in to wait for early morning light to see the buoys and make our way back to the dock. Well the water kept dropping and around 9:30 we were sitting high and dry sitting on the keel box and listed hard over to the port hull.
Let me inject at this point that I have NEW FOUND RESPECT FOR ANYONE THAT ENDS UP BEACHED ON A BOAT. With the boat heeled over at 45 degree's its impossible to easily move around inside. I started CPN to check the nearest tidal station to us to find out when the high tide would be. I found out that it would not arrive in our location until about 3:00 AM. Ok so we break out the stove and prop it up so that its sitting more or less level and make some coffee and food. I toyed with getting out and setting the anchor as we both intended on trying to get some sleep, and I didn't want us to be asleep and start drifting at the high tide. In the end I didn't as I figured that one of us would wake up as the boat started to right itself on the incoming tide. Trying to sleep in the v-berth laying accross the beam does not work lol way to cramped. Both of us kept sliding down toward the port side, so had to kinda use our feet to push back to the starboard side. Sas gave up about 12:30 and got up and I followed her about half an hour later. Around 1:00 AM or so the sand we were sitting on again began to be covered by water. By 2:00 AM the port hull was starting to float once again and it was begining to be a bit easier to move around inside as she went from 45 degree list to 30 or so. We now decided to sit down and get the chart plotting software up and running. The problem was that our gps usb puck antenna's native mode is to transmit data in the SIRF format which OpenCPN doesn't understand. Finally we figured out the proper sequence of commands to get it to transmit in NEMA sentences and OpenCPN finally recognized the data and showed our position on the chart. As it was we were about 0.17 nm east of the channel before the first hard turn and about 80 meters north of the channel in that short leg of it between the two hard turns in it. By about 2:45 she was righted once again although we were still aground. We decided to start up the outboard to give it time to warm up as we figured that in the next 15 to 20 minutes we'd be floating and able to back off.
We had lifted the outboard bracket to the up position as the tide waned to prevent the leg maybe being damaged. Its a PITA to get it down so we left it up. In this position the cavatation plate is only about 6 inches under water so you have to motor pretty slowly and changing from forward to reverse or visversa causes cavitation. Ok so the outboard is running although still not ideling very smoothly and prone to stalling when the revs drop to low. The bow finally starts to swing around with the incoming tide so I back us up into what we know to be safe water (depth). Sas is in the cabin watching the chart and directing me as to steerage ie port or starboard to get us back into the channel again. Once we're back into the channel she keeps giving me directions to keep us in the center as we motor back to our dock. After about an hour we are suppose to be back but can't see the docks as its still dark out. The current pushed us slightly north so we turn and begin motoring south towards the light in the parking lot. My concern being that there is a boat on a mooring and I didn't want to hit it. After a few minutes though we could see the only other boat in the water at the docks and new where we were relative to our own dock. Of course the motor stalled in docking and darkness!!
Nothing serious but a PITA anyhow. Finally tied up again we unload and head home for some sleep.
:redface:
Lessons learned (relearned):
1) Always check the tide before leaving
2) 2 feet of draft might as well be 5 feet (don't be arrogant about floating in shallow water)
3) Always have at least a gallon container of water on board. ( Our water tank only had about 8 gallons in it and when heeled over and dried out the water pick up was sucking air only.
4) Always have food onboard (we did but not plentiful amount)
5) Always have at least 1 extra gas tank for the stove
6) Have a high powered flood or spot light on board
7) GPS can only be trusted to 60 feet or so as to actual position.
8) OpenCPN is reliable software and the CM-92 charts we have are pretty accurate. (better in fact then the paper chart we have of the area)
9) Always have a second set of clothes on board even for a short short trip.
10) have sweaters sweatshirts etc aplenty on board
11) have a shovel so that if this happens again we can at least go clam digging
12) our msd doesn't work when the boat is laying on its side!!
13) a deck light is handy when its dark even on a small boat.
14) always have the charting program running before leaving the dock.
15) when in unfamiliar waters use the charting following feature to capture your course during daylight hours and save it rather then relying solely on the displayed charts and gps location.
16) don't rely solely on your engine when docking.
I am sure there are other things here as well. All in all an interesting day on the water/SAND. On the plus side the aft locker drain plug had a minor leak due to not seating well, which I was able to repair while dried out lol.
Brina
576
Island Packet IP31 Lake St. Louis, Montreal
Brina
I'm glad you made it back safe and sound.
I particularly like point # 11 on the lessons learned!!
Matt
May 6, 2012
303
Hunter 28.5 Jordan, ON
Great story-telling and appreciate your willingness to share.
I sometimes lament the fact that I don't get to experience the run aground/wait for the tide to float off scenario here on Lake Ontario... and then I give my head a shake and hope for the best.
Rick D
Jun 14, 2008
7,186
As My Daughter Would Say...
...another learning experience!
I once mistook the range lights in San Diego and plowed across the shoal. What's worse, the guy on the chart plotter told me but I was so sure I was right...
May 27, 2012
1,152
Oday 222 Beaver Lake, Arkansas
Glad you got out without much more harmed than your pride.
Regarding point #7, I would argue not to trust GPS for anything other than a back up.
Dec 20, 2010
294
Thanx :)
Had it not been for the charting program and GPS we would have had to somehow anchor and wait for the first light of the day. That might have been difficult given that we were both tired and the incoming tide runs at about 2 1/2 knots. These are totally unknown waters to both of us. Our paper charts shows the channel but not the buoys as they are private. Hopefully this week we will actually get out the inlet and actually do some sailing.
c_witch
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
c_witch
c_witch, great story! You should submit it to Sail Magazine. They have a monthly article on lessons learned in these situations. At least you can get paid to share your lessons learned the hard way!
Very glad you made it out without a serious problem.
Oct 26, 2005
2,057
- - Satellite Beach, FL.
You had a problem, figured out what you needed to do and did it without help.
Good on ya!
Nov 6, 2006
10,095
You guys worked it out, stayed cool, and handled the situation.. GOOD JOB !
There were some lessons and I'll bet those learning's stay with you throughout your sailing to come ! Take 'em to heart and press on SMILING !
Oct 10, 2009
1,045
Catalina 27 3657 Lake Monroe
I loved that you tried to catch some shut eye. I'd have been way too wired to try to sleep. Thanks for sharing, but for the grace of God, as they say...
May 25, 2004
958
Hunter 260 Pepin, WI
I had a similar revelation this Saturday. It was the first time I have ever tried to unlock my boat after dark. The cell phone was enough light to see the numbers and do the combination, so we did get the hatch open and the lights on.
I now have a small flashlight in the ditty bag we carry to the boat each visit.
We have returned to the boat many times in the dark, but always after it was already open. I had no idea how limited the lighting was in our marina until I attempted to see the numbers on that lock.
I don't think you have any reason to have your pride damaged. That sounded like real "hard core" sailing to me. It is what people did before we had GPS, and quality charts.
And boy do I love my swing keel. I honestly don't pay as close attention as I should to depth because I know I can always raise my keel and push myself off. I've grown a bit lazy and complaisant. And although I only draw 12" with my keel up... I have to admit that I've run aground a few times, :redface: especially in the shallow waters of the Pamlico Sound.
I used to have a Coronado 23' that drew about 4.5'. We hit bottom hard once on an uncharted shoal. My brother-in-law hiked way out on the shrouds to get her leaning over while I jumped in the water and pushed us off. And I used the same trick last summer when I hit bottom while sailing a Ranger 29' in the Chesapeake. My daughters hiked out on the shrouds while I pushed us back to deeper water.
Stuff happens... and the more you play the more it happens.:D
Oct 9, 2007
17
McGregor 26 Napa, CA
Aground
Only two types of sailors:
1) Those that have run aground
2) Liars
May 27, 2012
1,152
2) Liars
Similar to taildragger pilots, those who have ground looped, and those who will.
Ive run aground a few times, worst was in a backwater off the Mississippi south of St Paul. Depth went from 20 to zero so fast, thought it was deep water being near barge docks.... motor kicked up and slid to a stop in mud. And of course, it was dark O thirty. Brother and I had to get out and push it back, yuck.
Reason I questioned GPS is because it can fail without warning; dead batteries, unit death, grid failure..... If it is your only navigation tool you could find yourself in trouble. Certainly use it, but I would suggest having good maps and knowing where you are continuously.
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
c_witch, Enjoyed the adventure and the way the two of you worked it out. I've been aground many times, all but one were soft groundings, all unmarked. It goes with the joy of exploring new waters.
I also use my GPS along with area paper charts and have found the GPS to be very accurate over ground and water.
Please write more of your stories. They are good reading.
Ray
Dec 20, 2010
294
Hiee Ray,
Thank you, I will do that as the adventure unfolds. Hopefully we will not have any more groundings lol.
The ENC's we were using are the CM-93's 2010 ver II. It was taken from the CHS charts compiled by the CHS here in Canada. Last week in talking with a fellow member at the club we discovered that the channel has moved and is no longer in the position as represented on the paper chart. I guess we where fortunate as that is the course we followed in that morning but on a raising tide.
c_witch
