Greetings. I have a new Catalina 309 and am tryig to install a CD/AM/FM Stereo. The speakers were easy to hook-up since the boat came pre-wired fore and aft. The Nav Station had a precut location for installing the CD unit, so that went well.Unfortunatley, after attaching the power and grounding wires as instructed in the stereo manual,the unit does not turn on.I assume it is because I am hooking the wires up to the wrong locations behind the Nav Station.I hooked the yellow wire (for memory and back-up lead)directly to the positive buss (where all the other wires going to it were Green or White).I hooked the red wire (the Power lead) to the male plug connector next to the "Stereo" accessory switch on the DC distribution panel.I hooked the black wire (the Ground lead) directly to the negative buss (where all other wires going to it are black).But no power! Any ideas about how I screwed up?Thanks!
