L
Les Blackwell
My wife and I have just had the perfect summer of cruising aboard our H380 in the Pacific Northwest. I do not remember in the past 35+ years of such good cruising. The weather was good, the boat was excellent, the friends we met surperb! Probably the biggest downer was that a favorite bakery has quit business. Pity.We did 55 days with several stops home to reload and to handle family business. Our longest time out was for 25 days, mostly with a sister ship whoes owners had not done much cruising.We covered the San Juan Islands, the Gulf Islands, and Desolation Sound, the latter part was in the month of September. Not many boats travel north at this time of the year, so the anchorages was almost empty. We sat out two gales at docks by keeping tabs on the weather on VHF and we crossed the Strait of Georgia both ways in calm weather. Even the notorious Whiskey/Gulf area that is a topedo range was inactive.Our boat worked exceptionally well for the two of us and two cats. We have a furnance so that took the chill off in the mornings. Our dodger took away the chill when the wind blew. When we got home, we still had steaks in the freezer which basically meant that the resturants were excellent.Our ports of call were Friday Harbor, Sidney, Ganges, Nanimo and Lund, the latter four are in BC. In fact, Nanamo has a Dinghy Pub on Protection Island that is a great place. We celebrated my retirement there.For those in the older category, this may be of interest to you--I put a Forespar lifting device on the stern and it is so easy to transfer the outboard to the dinghy with this in control. I use a Honda 2 hp outboard which weights 29 lbs. I found this to be "iffy" when doing it myself attaching it to the Avon. Using the lifting arm solved this problem.Fuel use using a Max prop was slightly less then a gallon per hour. We did almost five hundred miles mostly under power or power sailing. Very little winds this time of year.What would I like for the boat? I will be looking for a way to heat water when at anchor. I have enough power to stay at anchor for 4 or 5 days for the freezer/refrig but we run out of hot water and don't want to run the engine. There must be a way to have hot water.I used one tank of LP for most of the summer (1 10 lb tank). Was able to fill up at one of our stops.Biggest problem? laundry. We had a ton of it when we got home. In September, many of the places that have washer/dryers are almost all broken for the season. Try again next year was the answer from marine places.Someday I'll write about the boat and what we have done to her. But for now, it has been the perfect summer of cruising on the perfect boat. I don't think I've ever said that before.Happy fall cruising to you all.Les
