A new use for Bed It butyl tape
Nov 26, 2008
1,970
Endeavour 42 Cruisin
Bed It butyl tape made it all possible!
In the future, if the windows need replacing, no sewing. Unscrew the machine screws and pop in a new panel.
I'm also going to attempt to modify canvas snaps and add them to the nuts outside where I could then snap on an external cover. We originally had an external cover with velcro but the velcro fell apart in no time from UV.
Nov 26, 2008
1,970
Yea, the cockpit enclosure does look a bit boxy, I did climb out of the cockpit to think this over ;-)
Sep 2, 2011
1,041
Hunter 27 Cherubini Alum Creek State Park
Cool!
This has nothing to do with butyl tape, but since I'm planning to mount my new solar panel to the top of my Bimini, what kind of mounting hardware did you devise?
What are the little white spacer blocks?
Nov 26, 2008
1,970
The bars are aluminum and the white spacers are starboard. You could also use celtek pvc sheet goods for spacers.
I drilled right thru the bimini bows and drilled the sunbrella with a soldering iron. The aluminum flat bars sealed the sunbrella holes completely, not a drop in 2 years.
